Re: 2 way hydraulics
Posted by Bob Kerr on October 10, 2007 at 08:32:15 from (205.188.116.73):
In Reply to: Re: 2 way hydraulics posted by Nat 2 on October 10, 2007 at 08:01:49:
I have the IH christmas tree type on my M. The lever on top of the valve is getting a bit sloppy and I sometimes have some trouble getting it to go up or down. You might check that out if you have that type.
