Re: Farmall H Valve Springs?
Posted by Nebraska Cowman on October 10, 2007 at 10:43:32 from (65.162.146.41):
In Reply to: Farmall H Valve Springs? posted by Aaron B on October 10, 2007 at 10:33:34:
The springs are fine. Somebody sold you the wrong valves. Gasoline valves are longer and will not work in a kerosene or distilate head.
