Re: 2 way hydraulics
Posted by Dalton S. on October 10, 2007 at 15:27:56 from (70.41.44.145):
In Reply to: 2 way hydraulics posted by Dalton S. on October 09, 2007 at 20:27:04:
third party image
It is not live hydraulics. It is two way because there are two hoses going to the back and there is a second lever to operate it. It is the christmas tree type. I have a ten foot disc I pull with it. I can only use the weight of the disc to get the disc down. The hydraulics will not compress the piston, they will only push it out. The little lever beneath the rod doesnt move.
