Re: 2 way hydraulics
Posted by Bob Kerr on October 10, 2007 at 21:48:04 from (205.188.116.73):
In Reply to: Re: 2 way hydraulics posted by Dalton S. on October 10, 2007 at 15:27:56:
That is the type mine has, and it does pull the cyl back in but my system runs off the Belhen PS pump instead of the belly pump but it shouldn"t matter. I have 3 point that it runs. I am not sure what the little lever below the main lever is for, mine seems to never move either outside of flopping loose if I move it by hand. I would suspect that there may be a problem in the top part of the valve where the main lever is. I am not sure where to get parts for those and I have a feeling IH doesn"t have them anymore. Does your main lever have slop in it?
