Posted by glennster on October 11, 2007 at 07:57:01 from (76.224.26.7):
In Reply to: Neblinc posted by Mike CA on October 10, 2007 at 15:11:07:
mike, a hardware store should have an assortment of springs, farm and fleet also has a good selection. finding something close to your spring shouldnt be a problem, i usually get them a little long and then cut them to length. if you need to shim up the radiator, get an old mudflap from a semi truck and use a hole saw to cut out some disks to use as spacers. cut a slot from the outside of the shim to the center so you can slide them between the radiator and the bolster to line it up.
