Re: Live hyd pumps
Posted by Owen Aaland on October 11, 2007 at 15:14:42 from (65.174.247.81):
In Reply to: Live hyd pumps posted by Bryce Andreasen on October 11, 2007 at 13:57:00:
The pump is NOT the problem. If it were you would not have any better steering when you moved the control valves.
It sounds like you are missing or have a defective flow control valve. Is this a factory installed power steering or added later? If added later, you also need to change the flow control valve to one that includes a priority valve to make sure that the steering gets priority over the control valves. Without a priority valve you will have the condition you are describing.
