Re: 886 Light Problem
Posted by Steven f/AZ on October 12, 2007 at 11:53:41 from (216.67.213.217):
In Reply to: 886 Light Problem posted by Lance_MF_180 on October 12, 2007 at 11:21:29:
I know on our 1086 the relays and fuses/breakers are under the steering column - if that helps.
I also know that I"ve had to clean up the connections a few times to keep the lights working, as well.
