Re: Fram filters
Posted by Jim J on October 13, 2007 at 09:55:46 from (12.189.32.38):
In Reply to: Re: Fram filters posted by ddg on October 13, 2007 at 06:51:03:
Dodge had a TSB on Wix filters (Napa, CarQuest). The TSB said do not use Wix The way the filter is put together the are small pieces of the anti-drain back valve on the clean side of filter and the can and will plug the piston coolers causing engine failure.
