Re: Super A compression and oil burning question
Posted by DCW on October 13, 2007 at 19:54:40 from (156.34.197.105):
In Reply to: Super A compression and oil burning question posted by SteveNH on October 13, 2007 at 19:40:41:
You may have good compression,but that doesn't mean that the oil rings are good,you may have one or more stuck or broken.You may have excessively worn valve guides.Running it that way won't hurt it,but it will likely need to come apart.It won't work right if its quickly fouling plugs.
I'm unsure if 115 is out of range for compression,if it is,its just out of range.Does it blue smoke,maybe its fouling plugs because its too rich.
