Re: Farmall H with JD 45 loader
Posted by chuck46 on October 14, 2007 at 20:35:55 from (64.136.27.229):
In Reply to: Farmall H with JD 45 loader posted by Vito on October 14, 2007 at 14:00:27:
Hi Vito, I assume you have a belly pump on your H. The front of your cylinders will increase the volume of oil. Remove the filler cap and dipstick from pump, replace it with a pipe union then a bushing to reduce to 1/2 inch pipe then a 3 inch nipple with a tee, then a nipple aimed both left and right and finish it with fittings to match your hoses. This is a common installation because the H and M did not have a large enough resovoir for two large cylinders. Good luck, Chuck
