Thanks for the Replies. It is blue smoke, mostly bad at idle, at higher RPM"s it doesn"t look as bad. I will run it for a while and change the oil a couple of times, I put Non Detergent 30 in when I brought it home, it always turned over freely so I am unsure of the condition of the oil rings. I am going to eventually order a 3 point hitch kit for it (Worksaver?) and put it to work around the yard. After my small projects are done I will take the engine apart and go through it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
