Re: 1206 TA
Posted by the tractor vet on October 15, 2007 at 09:05:34 from (76.212.225.141):
In Reply to: 1206 TA posted by Dubl J on October 15, 2007 at 08:14:53:
Now from what i have seen and unless they have got all the bugs out of them now Myself i will not use one . When i had the shop open and were doing them i installed Hy. Capacity products and to this day all that i installed as still going strong . WHere as the one that were being installed at the local Case I H store were not doing so well . If a T/A is installed properly then they will last many years . Do you know about setting end play? do you know about going thru the MCV or setting the end play on the bottom shaft and shiming the lower shaft gears . Flow rating the MCV pump setting pressures . Doing the job is not just droppen in a new unit.
