Re: Farmall M Diesel Piston Removal
Posted by Mike Farmer on October 15, 2007 at 11:46:44 from (81.107.136.160):
In Reply to: Farmall M Diesel Piston Removal posted by Maas on October 08, 2007 at 07:22:30:
You can channge the bearings but you won't be able to check the wear on the crankshaft,so you may just knock out a new set very quickly. If you think it needs doing then I guess your going to have to 'bite the bullet' and take the engine out. Luck! Mike Farmer
