Re: Front steering shaft
Posted by Janicholson on October 16, 2007 at 18:07:06 from (66.173.50.158):
In Reply to: Front steering shaft posted by Wardner on October 16, 2007 at 14:32:09:
I'll add to the sage advice below that the shaft might turn out to be pretty darn hard to work with. It is not mild steel. If turning and drilling are needed it might be OK but welding to it might be tricky unless care were taken to use the correct process/rod. JimN
