Posted by Mike Farmer on October 17, 2007 at 06:16:25 from (81.107.136.160):
In Reply to: M water in the oil? posted by pete_5959 on October 11, 2007 at 17:45:38:
One of three. Head Gasket. Cracked head. Head is warped. ( These may be considered but extremely unlikely. Cracked block internally. Incidently altho its very rare with a head gasket damaged just at the top of the liner water can get forced down past the liner. Basically if theres room for grease to help assembly theres room for water)
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
