Re: Where does voltage regulator mount on a '48 Super A
Posted by Gene-AL on October 17, 2007 at 09:51:19 from (74.242.20.239):
In Reply to: Where does voltage regulator mount on a '48 Super A posted by SteveNH on October 17, 2007 at 07:47:44:
Super-A (1951) has the voltage regulator mounted below the generator and a 3-position light switch (O-D-B). One mounting hole on the VR bolted into the generator mounting bracket between the two bracket mounting bolts.
Other SA's with 4-position light switch (L-H-D-B) and magneto ignition had a cutout relay mounted on top of the generator (L-H positions on light switch substituted for the VR function).
The generator has a threaded hole for the belt-tightness (slotted) bracket. Just a bolt w/washer - don't know the size.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
