Re: Where does voltage regulator mount on a '48 Super A
Posted by Janicholson on October 17, 2007 at 12:51:35 from (199.17.6.122):
In Reply to: Where does voltage regulator mount on a '48 Super A posted by SteveNH on October 17, 2007 at 07:47:44:
A regulator equipped genertor (delco A type) grounds the field to make it charge. The connection to the light switch is not used at all. The light switch wire that was connected to the field terminal should be disconnected from the light switch, and disconnected from the generator, and not used. The F terminal of the reg is connected (#12 wire) to the Fterminal of the gen. (small terminal)
The Bat terminal on the reg is attached to the side of the amp meter away from the connection attached to the starter switch (10gauge wire). The Gen terminal on the Reg connects to the A (big) terminal on the gen. The lights will continue to work correctly with this change, the switch will have two OFF positions L and H. The D and B positions will still work the lights. Be sure the regulator is well grounded, and polarize the gen (with all wires connected, and the battery in and connected) before starting by jumping briefly (1 second) between the Gen terminal and the Bat terminal on the reg. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
