Re: 560 -shifting
Posted by Janicholson on October 17, 2007 at 13:35:59 from (199.17.6.122):
In Reply to: 560 -shifting posted by tlee on October 17, 2007 at 12:10:17:
It is the first sign of a TA that needs to be adjusted. If the clutch is being pushed in all the way to the stop, it should shift either way. A manual is the only way to be sure it is adjusted correctly. Be sure to repair any worn pins or cleveces in the linkage befor adjustment. Loose pins, and augered out holes are difficult to adjust accurately. Failure to adjust will burn out components!!! JimN
