Re: cub problem. HELP!!!!!
Posted by El Toro on October 18, 2007 at 15:30:55 from (64.12.116.73):
In Reply to: cub problem. HELP!!!!! posted by russ hamm on October 18, 2007 at 07:15:49:
third party image
Are you sure it was timed on the compression stroke with No1 piston at TDC? Hal
PS: Check that suction on the carb when you hold your hand over it when cranking. Make sure the valves have enough clearance too.
