more 1-PR corn picker questions
Posted by riverbend on October 19, 2007 at 17:35:37 from (208.160.34.197):
The lower extension (the curved sheet metal piece at the bottom of the elevator) and wooden blocks for the wagon elevator are rotted out. I discovered this when the elevator chain broke. Is this going to cause me a lot of trouble if I use it this way ?
How tight should the elevator chain be ? I have a service manual, but not an operators manual. The service manual only says that it is an aquired feel and the chain should not be fiddle string tight.
How do you park this thing ? It acts like it wants to tip over backwards when I unhook it.
Any good ideas for working the kinks out of the gathering chains without having to remove them ?
Thanks
The man who sold IH grease fittings in the fifties must have retired rich.
Greg
