Re: How do you remove the lower front bolster?
Posted by gots-2-go on October 20, 2007 at 10:08:24 from (69.72.55.202):
In Reply to: How do you remove the lower front bolster? posted by Mike CA on October 20, 2007 at 08:46:06:
Mike,
Knowing that you have a small boy please make sure you block the tractor safely.
Also if the bolster that is on your tractor has the tapered spacer (as some call it) you may want to hang on to it for the narrow front that you plan to install.
Have you been able to locate a narrow front yet?
