Re: How do you remove the lower front bolster?
Posted by Lee in Iowa on October 20, 2007 at 12:03:21 from (66.172.198.92):
In Reply to: How do you remove the lower front bolster? posted by Mike CA on October 20, 2007 at 08:46:06:
When I had to do quite a bit of work to a larger tractor, I jacked it up with a hydraulic jack under the center behind the motor and then mounted tall implement jacks on each side frame to stabilize it. Just make sure you break the 4 bolts loose before you jack it up. Lee
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
