Re: How do you remove the lower front bolster?
Posted by Wardner on October 20, 2007 at 12:14:07 from (4.154.246.71):
In Reply to: How do you remove the lower front bolster? posted by Mike CA on October 20, 2007 at 08:46:06:
On a SMTA, the four bolts on the bolster steering shaft are not interchangeable between the narrow and wide. The narrow front bolts are 1/2 longer.
I imagine the same circumstance applies to the H. Keep the bolts and front ends together.
You will have to turn the steering to get a wrench on the bolt heads. Plus you will also have to turn the steering to get the bolts out.
