Re: voltage at alternator reading
Posted by Janicholson on October 20, 2007 at 18:28:32 from (66.173.50.72):
In Reply to: Re: voltage at alternator reading posted by keith smith on October 20, 2007 at 17:58:56:
A coil going bad is usually very hot to the touch.
A coil designed for use with a resistor will usually have printed on it "for use with external resistor" if it does it need the resistor. 57 chevrolet resistor is great.
Be sure it is spark by trying this. Take an old coil wire and cut a gap into it through the conductor like a V. make the gap about 1/16" wide. use this in place of the regular coil wire. Spark will show in this gap when running. as it quits the spark will fade if it is the coil. if it does not, suspect fuel supply issues. JimN
