Re: voltage at alternator reading
Posted by keith smith on October 20, 2007 at 17:58:56 from (67.72.98.45):
In Reply to: Re: voltage at alternator reading posted by Gene-AL on October 20, 2007 at 17:27:29:
gene al
i did my hook up exactly as you discriped
so i feel good about the volt meter. thanks
still not sure why i cant get a good reading from
my digital meter? less like bob said, too noisy
a beast. might be why i get a good reading off
my volt meter though.
main reason of my concern is, my tractor is
acting like the coil is going bad again. after
i run for about 10 min it quits running.... after waiting about a half hr it will start again and so on. i just replace my coil about
two weeks ago. it burn up along with the wires
to and from it, not to mention the points.
this coil is suposed to be able to run without a resister. beginning to wonder if i should put a resister in it???????
thanks for all your help guys
