Re: voltage at alternator reading
Posted by El Toro on October 21, 2007 at 04:54:42 from (205.188.116.73):
In Reply to: Re: voltage at alternator reading posted by keith smith on October 20, 2007 at 17:58:56:
You can buy a coil from Napa that has a built-in
ballast resistor for about $40.00. The Napa number is 1C14SB. Hal
