Re: knocking noise from engine area
Posted by Scott Rukke on October 21, 2007 at 11:56:13 from (67.183.230.71):
In Reply to: knocking noise from engine area posted by WonderingAl on October 21, 2007 at 11:29:21:
Could be many things. The question is whether low oil caused it. Depends on the type of noise and where exactly it's coming from. A rod bearing is usually a deeper knock than say a lifter. Run the engine and pull 1 plug wire at a time and see if any of them make the noise stop. Sometimes by doing this, if it's a rod, the noise will stop when pressure is taken off the bearing. As for repair, if this is what it is, it requires a total engine tear down, crankshaft grind and over size bearings. Plus all the other things that are required with a rebuild. You can price rebuild kits on line but then you'll have to check local machine shops for the machining costs associated with a rebuild.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
