Re: Help Farmall C guys....
Posted by Justin S. - TX on October 21, 2007 at 15:51:15 from (70.117.196.72):
In Reply to: Re: Help Farmall C guys.... posted by Justin S. - TX on October 21, 2007 at 05:40:52:
I looked online at the A-295A plow, if the C-295A is similar this is not the right plow. This set of plows hangs on a 2" square steel bar that is mounted to some lift frames. This whole assembly is right underneath the motor/clutch housing.
