Posted by russ hamm on October 21, 2007 at 18:00:41 from (63.245.179.200):
As some of you know, i had a post about this cub last week. Saturday night i checked it over again and still no go. Sitting there thinking, i remembered that most times when we do a 10-20 or w-30,etc. they are somewhat hard to spin over at first, so we usually belt start them. I put a good 12 volt battery on in place of the 6 as it is a mag tractor. It spun over quite fast then, and i noticed the suction at the choke end of the carb was extreme. I turned it over for about five seconds three times and on the third try IT TOOK OFF!!!!!!!!!!! After break-in running, it would start easily on the 6 volt battery. This was all after several weeks of triple checking many things on tuesday evenings and saturday nights. I THINK that POSSIBLY the two fellahs that overhauled it did not put a whole lot of oil on the pistons and rings. We did suspect that and squirted some oil in the cylinders early on, but a weak mag at that time and slow turning over with the 6 volt battery may have been the problem. After the mag rebuild, it still turned over slowly, and i guess too slow for initial startup. Thanks to all who contributed ideas, cubs may be okay afterall, we just needed to belt up or spinner over without the plugs in for a while. :^D
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
