Re: Cub won't start update
Posted by ScottyHOMEy on October 21, 2007 at 18:59:03 from (71.241.212.142):
In Reply to: Cub won't start update posted by russ hamm on October 21, 2007 at 18:00:41:
Might also look at the impulse coupler (or maybe bail some light lube to it while the engine is running) on the mag in case it's been sticking to where it won't fire right at a low cranking speed.
