Re: Farmall H has low oil pressure
Posted by 4 Farmall Scott on October 21, 2007 at 18:10:45 from (65.214.236.164):
In Reply to: Re: Farmall H has low oil pressure posted by Janicholson on October 21, 2007 at 09:30:33:
My gauge goes from 0 to 75 with no numbers in between so it makes it hard to know what PSI your running at. I put 30W oil in it yesterday and after running it for about 2 hours when i turned it down to idle it went way down to just above the 2 lines above the 0. Today i put 15w 40 oil in it and it seemed to be better. There in no knocking noise, it runs great.
