Re: knocking noise from engine area
Posted by noncompos on October 21, 2007 at 20:32:38 from (65.102.63.107):
In Reply to: knocking noise from engine area posted by WonderingAl on October 21, 2007 at 11:29:21:
It's possible you might luck out, if this's the M that holds 8 qts; down 4 would still leave 4, or 4- if down 4+ (4+= how much?). It wouldn't be the first time low oil churned up some crud and maybe stopped up an oil hole for a rod or something else without messing up the rest of the stuff. Scott's check is easy to try. You said filled with oil and knock still there, but had supposedly been knocking for awhile (how long? before oil got low?). Is knock audible while: idling? pulling? revving engine slightly in neutral, or when slacking off hard pull?? But don't get your hopes up; most likely it's something expensive.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
