The quickest way is probably to have a poor connection in the wiring somewhere between the alternator's output stud and the battery, causing wild voltage surges, and, if there's no diode, resistor, or "idiot lamp" in the "switched excite circuit", the alternator will attempt to charge the battery through the "excite" circuit, "killing" it's internal diode trio and/or voltage regulator. These diagrams show how that happens:
Also, if the alternator is poorly grounded, or the #2 "voltage sense" connection is not properly connected, possibly the alternator will "lose it's smoke".
I wish I could "autopsy" your failed alternators... that would give a good idea if it was just freak failures from a couple of "bad" alternators, or just WHAT is failing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
