3 amp diode will this protect alt???
Posted by keith smith on October 21, 2007 at 17:48:56 from (67.72.98.45):
looks like i cooked another alt
replaced my alt (napa 2134508d) and it died after
hr of replacing it.
jim you say to use a 3 amp diode in excite wire
will this protect my alt???
coil and alt run off same side of the (on off) toggle switch. ... could the coil be spiking the alt???
by the way i bought a analog volt meter and i did
show that the alt was charging at the alt battery terminal...for a little while any way.
not
