Re: knocking noise from engine area
Posted by Brownie450 on October 22, 2007 at 06:09:57 from (207.177.82.216):
In Reply to: knocking noise from engine area posted by WonderingAl on October 21, 2007 at 11:29:21:
Before doing internal work, check for a loose flywheel/ pressure plate/ clutch disc thing. Also look into the front pulley/ water pump area. This is easier to check than tearing into the engine.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
