Re: knocking noise from engine area
Posted by Brownie450 on October 22, 2007 at 10:54:49 from (207.177.82.156):
In Reply to: knocking noise from engine area posted by WonderingAl on October 21, 2007 at 11:29:21:
One other thought=-- Have you had the valve cover off to look at the upper head area? Could be a valve out of adjustment or a pushrod jumped out of it's socket. If one of the valves isn't opening or not opening all the way, you'd be getting noise from that particular cylinder. Not likely, but easy to check.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
