Tach drive gear lubrication
Posted by SDE on October 22, 2007 at 17:00:00 from (69.179.21.63):
When you grease the distributor shaft, Will some of it go down into the tach drive area or is it a seperate compartment.
Should the tach drive get 80w90 gear lube or grease? Would grease become to stiff during the cold winter weather?
Thank you
SDE
