Re: belt pulley
Posted by the Unforgiven on October 22, 2007 at 17:46:30 from (66.146.249.116):
In Reply to: belt pulley posted by Oldiron29 on October 22, 2007 at 17:18:31:
Hi Oldiron, take the pulley and drive off as a unit. People have told me that you also have to double-nut and remove the studs that hold the drive on to get clearance on the 20. I don't know that for a fact, last week I changed out the drive assembly on my F30NT without removing the studs. Don't forget to knock the nut on the pulley loose before you remove the assembly, it is much easier to drop it in gear to hold it than it is to hold it on the bench.
