i am loading a picture so you can see the hookup of the harness preveous owner used http://members.localnet.com/~woodslip/harness.jpg
red wire far right is the excite wire. that is the only wire used...yellow connector other end is where it connected to lead from switched side of on off toggle. other wire was not hooked up at all.
looks like he used original wire going from alt bat term to starter solenoid.
funny didnt have problem till i changed the excite wire from alt bat term to the switched side of toggle.
he put in a seperate toggle switch for the alt bat wire. told me to toggle it off or would drain bat....as it did.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
