Re: H engine occasionally stuck
Posted by Mike Farmer on October 23, 2007 at 00:55:06 from (81.107.136.160):
In Reply to: H engine occasionally stuck posted by D. Raymond on October 21, 2007 at 19:55:55:
Forgot to say-next time it happens take rocker cover off and check if you have a valve stuck CLOSED. If this is the cause it is either that a valve stem is not lubricating or the stem is slightly bent. Initially try an upper cylinder lubricating additive in your gas tank. That will cure it if its lubrication. If its a bent valve stem best pull the head off before it bends a push rod or tears the valve seat out. Mike Farmer
