Re: 1-PR Picker
Posted by Al M. on October 23, 2007 at 18:04:42 from (4.157.17.225):
In Reply to: 1-PR Picker posted by sflem849 on October 22, 2007 at 16:42:23:
Hi,
1pr is a good picker, you have to put more pressure on the husking rolls. The rolls use
compression springs on adjustment bolts located
on the ends of the husking rolls,at the gear drive
end of rolls you can see the springs there is one
bolt to adjust 2 sets of rolls to your left. The
3rd set of rolls to right has its own adjustment
bolt.Do not overtighten causes excessive wear.
Ajustment nuts are located on outside of tin work.
The same on opposite end. The rubber paddles have
to be in decent shape they put pressure on ears
so rolls can peel husks off. Can you lower paddles
any further? I made new paddles from old tires.
More pressure on husking rolls will make it
husk clean.My picker husks good.
