1953 SH Will not start or turn over
Posted by NE NEB FARMALL on October 23, 2007 at 18:38:00 from (12.186.41.114):
I came home today and tried to start my tractor. It made about 1/4-1/2 crank then nothing. I voltage tested my battery and had 6.12 volts and when I pushed on the start lever it went to 4.37 volts. I cleaned all the connections last week because it started hard. I took off the little rocker switch on the starter motor and I could see where the copper piece had been making contact. I touched the battery lead straight to the contact on the motor, It sparked but still would not turn over. Any suggestions?
Thanks!
