Assuming it is a good charged battery that holds a charge, and cables are clean and attached and of 00 size.
Either pull the starter out of the housing, or try this: With the ign. off put it in high gear then rock it violently back and forth with the top of the rear wheel. the fan should show some motion if it fixes it. (It will be a temporary fix) In either case it may make a clicking noise as the starter comes unjambed from the flywheel. Bolt it back on, or put it in Neutral, and try it again. A new clutch style drive (from CaseIH) replaces the original. If still no luck, taking the starter to a electrical shop for a test will be next. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
