Re: Will a bucket loader from Farmall model M fit a model H?
Posted by Dens71TA on October 24, 2007 at 10:42:59 from (128.104.48.212):
In Reply to: Will a bucket loader from Farmall model M fit a model H? posted by Dens71TA on October 23, 2007 at 21:40:28:
Here is a picture of the loader with it still attached to the M.
http://i238.photobucket.com/albums/ff245/dens71ta/loader.jpg
The seller calls it a "Freeman" loader so it must be aftermarket. If the only difference is the width of the frame rails I should be able to make some spacers to fit the H frame. Do the M and H have the same Lift-All system so all the hydraulic lines should hook up the same?
