Re: Will a bucket loader from Farmall model M fit a model H?
Posted by Janicholson on October 24, 2007 at 16:20:09 from (66.173.50.126):
In Reply to: Re: Will a bucket loader from Farmall model M fit a model H? posted by Dens71TA on October 24, 2007 at 10:42:59:
The hookup is the same, the units are not the same size, but identical in operation. Stay with the front outlet fittings on both sides. Be sure the adapter does not twist outward on the rails, or have a tendency to tip and pull out bolts. A cross member at the front might help. JimN
