Re: 685, 684, 674 hydraulic plumbing
Posted by Fromjb2 on October 24, 2007 at 14:26:20 from (99.241.179.24):
In Reply to: 685, 684, 674 hydraulic plumbing posted by karl f on October 24, 2007 at 00:39:42:
Karl,
hydraulic flow chart for these machines is pump>mcv, divided^>3pt lift>auxilary valves>>depth control>mcv.
The normal method of adding a loader or external hydraulic control valve is to remove the aux valve return pipe (685 Case-IH parts 8-406 item #18) and connect the pressure/inlet side of the remote valve at the elbow #11 on item #7 and connect the return pipe to the male connector that the original pipe was connected to. Parts 8-380 item #37.
Some of the newer tractors have a female cap on the side of the transmission just behind your right calf. This female cap can be taken off and used to cap of the male connection on item #37 and the return line can go on where the female cap was removed from.
To work on this the complete platform will have to be lifted on the 3pt hitch control side. This is not as big a job as it sounds but have to lift it straight up until it clears all the control levers and then block up with some wood.
It is a two person job unless you have an engine hoist or other like equipment.
Hope this is as clear as hydraulic oil.
JimB
