Re: wont run
Posted by Janicholson on October 24, 2007 at 16:09:49 from (66.173.50.126):
In Reply to: Re: wont run posted by Red Dave on October 24, 2007 at 15:10:55:
That is likely the answer. Putting it back will be a bit of effort. Pull #1 plug. Rotate the engine till air pushes out your thumb stuck in the hole. Put a piece of stiff vinyl covered wire in the plug hole and rotate till it is at the very top. Set the timing mark (hole in cover at flywheel) to TDC
Timing marks should be on gear in hole, and gear on governor. If not set the rotor to point to 1:30 (looking forward). Good luck, JimN
