Well, I charged the battery and I did get it to start. Ran rough and died and couldn't get it to restart. Good spark coming off the coil now, but I did notice the battery is still charging several amps off the charger. Still only 12.5 volts at the battery and little under 6V at the coil. A good battery should be 13.2 volts, 2.2 per cell. I need to check the plugs next, one more question. When I worked on it the other day I noticed there is a set screw adjustment that allows the distributor to rotate, this was loose. I tried get it back where is was. I assume this sets the timing of the spark from TDC. Not sure how to set this, is a dwell meter required? I don't have one. Other suggestions??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
