Posted by georgeky on October 24, 2007 at 22:14:05 from (64.12.116.73):
In Reply to: C/B Block posted by IndianaRed on October 24, 2007 at 19:41:28:
If your tractor has hydraulics it does not have a A or B engine as they did not have an opening in the block for mounting of a hydraulic pump. Likely your tractor still has rings for 113 and your IH man has given you SC rings. 1/8 inch larger than C rings. Just measure the bore to see if it is 3 inch or 3 1/8 inch. The engine number and tractor number should match, if original engine is in it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
