Changing Rear tires of Farmall H.
Posted by WonderingAl on October 24, 2007 at 22:45:31 from (66.32.220.92):
Am wanting to change out rear tires on farmall H. Would like to have knowledge, step-by-step if possible. Also, any special instructions on wheel weights or the potential oc the chloride solution within the tire? Method of draining? Bracing of the rear end? torque numbers on the bolts?? Any and all pertaining information that would result in a most satisfactory outcome would be greatly appreciated.
thank you all.
